400hp turbo
#47
RE: 400hp turbo
yea i wouldnt buy a turbo that i wanted 400hp out of off of ebay. I dont even think id get a 14b off there. Unless i find a dual BB 50 trim with a 1 year no questions asked warrenty or even a 90 day one
#48
RE: 400hp turbo
i wouldnt buy one even with a warrenty.. thats just as retarded.. you wanna know why? because what they do is replace it with another **** one.. and in a day or 2 it breaks again.. then yopu ask for ur money back and get "Sorry sir.. we only do exchanges"
#49
RE: 400hp turbo
Now i have to figure out which 50trim I want. I found these 2 but im having a hard time finding somewhere else that sells them.(50 trim dual bb)
http://www.slowboyracing.com/more.php?id=5045&
http://www.slowboyracing.com/more.php?id=5273&
I also found one on dejonpowerhouse.com
Model 5031REOften called the 50trim - Max Rated HP: 450
This is a very fast spooling turbo which works well on the street with a stock engine. It gives more power than a 16 or 20g with the durability benefits of water cooling and ball bearing center section.
Compressor wheel dia. 54mm - 50 trim Spool-Up 3000rpm on 2 liter
T31 Turbine wheel in a .63 A/R housing for good exhaust flow
Note: Flapper Door Models - select Wastegate actuator, Mid or Hi range, in accessories section
#50
RE: 400hp turbo
correct me if im wrong but isnt the FP Green pretty much a 50trim?
well i've made my "shopping list"
$3161.00
400hp+ setup
All products other than DSM link are from Dejonpowerhouse.com
$1336 – 50 trim dual bb with oil/water lines
$ 300 – 1000cc injectors
$ 100 – Walbro 255lph pump
$ 280 – Wide Band o2
$ 170 – 3" intake
$ 400 – FMIC
$ 575 – DSM link
$3161.00
