420a to a 4g63
Old Feb 16, 2005 | 03:44 AM
get435's Avatar
Default 420a to a 4g63
Hello all i am going to change my car from a 420a to a 4g63. I am getting a totaled eclipse rear end is gone. now i know i will need the whole motor tranny ECU but do the motor mounts for the 420 a work as in the position of the top mout on the 420a it is on the left and on the 4g63 is it on the left? also do you need the whole wiring harness from the 4g63.
Old Feb 16, 2005 | 07:05 AM
CT9A 4G63's Avatar
Default RE: 420a to a 4g63
i'm 99% sure u will need the whole harness..
Old Feb 16, 2005 | 02:20 PM
1398spdr's Avatar
you will basically need to put the entire engine bay, wiring, tranny, ecu and anything else you can think of into the other car, it would be easier and cheaper to sell your car and go buy a gs-t............. and i dont think the motor mounts match up..........
Old Feb 18, 2005 | 09:50 AM
get435's Avatar
well i can get a totaled eclipse for 500 bucks. and as for the mounts top one is an easy fix because it is on the other side. I think that just buying the totaled eclipse and fixing the one i have will be and just as time consuming. its hard to find a car that has a straght body.
Old Feb 20, 2005 | 12:53 PM
get435's Avatar
so dose anyone know if the bottom mounts are in the same spot?
Old Feb 20, 2005 | 06:40 PM
Spyderman9803's Avatar
yes
95EclipseGS95
Aug 19, 2007 12:42 PM
RCJr9186
Dec 8, 2006 06:21 PM
eclipse27
1st Generation
13
Mar 28, 2006 11:15 PM
unimaginable06
Jan 19, 2006 07:03 PM
get435
Sep 29, 2005 10:07 AM
