420a for evo vIII
Old Oct 16, 2006 | 03:33 PM
RCJr9186's Avatar
Default RE: 420a for evo vIII
right, yea i knew that it was positioned different but it is the same motor right? so if an idiot wanted to waste a perfectly good evo and take the motor out they could put into their 1g or 2g ecipse. right? just so i know?
Old Oct 17, 2006 | 01:11 PM
RCJr9186's Avatar
hey guys just lookin for a lil info about my last post. so is the evo engine and the eclipse 4g63 the same? if so, is it the 6 bolt or 7 bolt? if it's the 7 did they fix the crankwalk problem? on here every day and i can't recal ever seeing this as a topic so i don't feel bad not searching it lol
Old Oct 17, 2006 | 04:52 PM
slow420a's Avatar
It has the same motor code and specs(2.0 liter, dohc, manifold mounts and such) but it was reengineered to work "right". People do swap the 4g64 sohc head out of their 3g eclipse for the evo 4g63 dohc head. Also people swap out the 4g63 block in their gst/gsx for a 4g64 block to get more displacment. Knowing this information I suppose its possible but why would anyone ever want to bother with doing so? A 4g63 is a 4g63, and there are ways to solve crank walk with out getting a new motor.
Old Oct 18, 2006 | 09:43 AM
RCJr9186's Avatar
i know, i just wanted to knwo for sure that it was the same motor... that would be siq to see an AMS eclipse pushing over 1000hp... lol that's all i was sayin
Old Oct 18, 2006 | 09:48 AM
slow420a's Avatar
Proly wont ever happen, the eclipse is a tank.
Old Oct 18, 2006 | 01:19 PM
RCJr9186's Avatar
can you translate? tank = ? heavy?? if that's what it means.... isn't the EVO heavier than the eclipse?
Old Oct 18, 2006 | 06:39 PM
ORIGINAL: RCJr9186
EVO 3200LBS with awsome suspention and at full weight. with a MUCH better motor than the DSMs have seen from AMS.
Old Oct 19, 2006 | 10:14 AM
RCJr9186's Avatar
the whole point of all of my questions is could you drop one of the 1000+hp motors from an AMS evo into a 2g eclipse since it's the same motor?
Old Oct 19, 2006 | 10:17 AM
No because the engine the other way round 180 degrees.
Old Oct 19, 2006 | 11:35 AM
RCJr9186's Avatar
THANK YOU lol wait, if it's turned the other way wouldn't it make the evo motor a much better subsitute for a swap of the 420a?
