420a oil question
Old Apr 19, 2008 | 06:10 PM
Kaede.Noir's Avatar
Default 420a oil question
does anybody know where is the oil pressure sending unit on the 420a? i cannot find it manually nor on my haynes.... i could only find it on the 4g63
Old Apr 19, 2008 | 08:20 PM
tjbiker031's Avatar
Default RE: 420a oil question
i dont think the 420a have one. since its not on the cluster with the 420a's they didnt put one in. why you ask, you wanting to put in a oil pressure gauge and tie it in to the existing sending unit?
Old Apr 20, 2008 | 05:37 AM
Kaede.Noir's Avatar
yeah... i need that oil pressure gauge since i have a pretty weak memory and tend to forget a lot about the oil... but there's one though... i mean the cluster has it... every single car has a warning oil light... which i myself hve seen out of my own forgetability
Old Apr 20, 2008 | 08:47 AM
you have a low oil level sensor, i dont think you have low oil pressure sensor
Old Apr 20, 2008 | 10:55 AM
tjbiker031's Avatar
far as i know the 420a's dont even have the factory pressure gauge on the cluster either. but if your worried about changing the oil, or checking the oil regularly. just write notes on a calender or program the reminder in your phone.
Old Apr 20, 2008 | 03:54 PM
Kaede.Noir's Avatar
Damn... that no good news... and yeah i even got a nice widget for as a reminder.... but like i said.... im just way disorganized....
SO!... my only option would be getting one of those sandwich adaptors and put the pressure sensor that came with the gauge there? or is the low oil level sensor replaceable with that one?....im just contemplating possibilities cuz i already got the gauge and it was one hell of a deal
Old Apr 20, 2008 | 08:46 PM
tjbiker031's Avatar
the oil pressure gauge wont ever really tell you if your low on oil...if thats what your going to use it for. it will tell you that you lost pressure, but by then half your oil would be gone or you lost your pump. the only way to check your oil to see if you gotta add more is to manually check the dip stick. but you could puta sandwich if you just wanna monitor your pressure but i would just use an aftermarket gauge because factory gauges arnt accurate, they're more like a guideline.
why you worried about your oil, you got a leak?
Old Apr 21, 2008 | 02:23 AM
Kaede.Noir's Avatar
yeah... i think i do... and for some reason i hear a lil bit of knocking, kinda like if for somereason my oil thins.... but i dont have a blown gasket... my vacuum is fine... so i just wanted to check on if im running the standard oil pressure... and plus like i said... i got the gague as a good deal...
Btw.... i thought that if you drop down a lb or 2 you definitely need to check on the oil dont ya? haha
lancer0594
Feb 5, 2009 06:48 AM
zero_Wheeler
Jan 24, 2009 07:47 PM
halfasss101
Sep 4, 2007 02:35 PM
Catch22!
Aug 22, 2007 09:50 PM
RCJr9186
Dec 8, 2006 06:21 PM
