420a timing....
Old Jan 16, 2009 | 12:34 AM
210_DSM's Avatar
Default 420a timing....
I jus recently replaced my timing belt cus my car started idling off when i was driving. i replaced the spark plugs, wires and the coil and none of those things solved the problem so i figured it was the timing belt. After i put everthing back together and tried to start it, it rolled over but wouldnt start?? I also replaced the starter and it didnt help. Any ideas on wut is wrong?
Old Jan 16, 2009 | 06:27 AM
Default RE: 420a timing....
check to make sure you didnt unplug something like the cam position sensor. are you sure you properly timed the gears and crank
Old Jan 16, 2009 | 03:00 PM
210_DSM's Avatar
ok ill check that. ima take it all part again and jus re-do it to make sure
jallen28144
Sep 7, 2013 12:40 PM
halfasss101
Sep 4, 2007 02:35 PM
willdue
Jun 24, 2007 01:06 PM
97RS
Apr 25, 2007 01:38 AM
racerx55
Jan 16, 2007 02:24 PM
