95 eclipse
Old Aug 30, 2007 | 09:33 PM
soulbond99's Avatar
Default 95 eclipse
Would the crank sensor cause my coil pack to go bad? also cause my car to die with no priar symptoms?
Old Aug 30, 2007 | 10:19 PM
Dusty Eclipse's Avatar
Default RE: 95 eclipse
A little more background info would be nice.
Old Aug 31, 2007 | 12:07 AM
soulbond99's Avatar
I checkedpower plug on the coil pack with a volt meter and all three wires are testing around 12.7 volts. the signal wire from the crank sensor should only read about a half volt or so... Therefore I am thinking the crank sensor is bad and sending the wrong signal to the coil.. Is this right?
Old Aug 31, 2007 | 12:13 AM
usually a bad crank sensor would throw a CEL... and that never happened?
Old Aug 31, 2007 | 12:22 AM
soulbond99's Avatar
But is it possible because this is the last thing I can think of. Then I am out of Ideas
Old Aug 31, 2007 | 12:27 AM
lol, its a DSM, anythings possible.
