95 eclipse gs blowing motor 30amp fuse, need help
Old Aug 4, 2014 | 08:41 PM
Mike Howard's Avatar
Default 95 eclipse gs blowing motor 30amp fuse, need help
I noticed the car would just randomly shut of, so i would crank it and start right up. it would be fine for a few days then do it again. after 4 times of that it shut off and would not start again. under the hood i saw the 30amp motor fuse blown. replaced it and set crank and it blew again. I replaced the coil pack as it was bad, turned the key to acc fuse was good, cranked it and pop again.. i was told the ecu is toast under the hood. i do know when i saw the popped fuse the first time the ecu was so hot i couldnt touch it. I have checked the grounds and all are fine, battery terminals have corrision but will be cleaning them shortly. no frayed wires. i disconnected the alt from the fuse and cranked it and it pops still. so i hope it is the ecu. anything else i can check, hate to but a new ecu to find out it was something i could have missed. thanks in advance
litildevil75
May 2, 2016 07:25 AM
monsterbishi
Jun 6, 2013 07:18 PM
TSO Racing
Jul 2, 2010 04:25 PM
TSO Racing
Jul 2, 2010 08:43 AM
eotlou
Dec 15, 2005 05:45 PM
