95 Eclipse GS Rotor / brakes
Old Oct 16, 2005 | 10:17 PM
Sanguinius's Avatar
Default RE: 95 Eclipse GS Rotor / brakes
Nah the rim will get a little warm but not too warm for you to touch.
Old Oct 18, 2005 | 10:04 AM
get435's Avatar
If you know how to bleed brakes here is what i suggest doing taked the rim off get a c clamp and put one side in the outer part of the calaper and the other on the other side put a little pressure on it open the bleeder screw than twist the c clamp with the pressure applied close the bleeder screw pump the brakes a few times this should put the calaper where it needs to be with correct pressure when brakes are not applied.
romy
Mar 29, 2018 01:56 PM
msport_2_outlander
Jan 9, 2015 07:30 AM
ImAzn2
May 7, 2005 01:03 AM
Prophet
Sep 10, 2004 10:33 AM
prelude1911
Jan 22, 2003 12:03 AM
