95 Eclipse,no fuel,no spark
If the throttle plate is closed, air is still bypassing the throttle plate to cause the high idle. Check the BISS screw o-ring, throttle body gaskets, and the intake manifold gasket. If none of those are the culpret it may be the FIAV or the throttle seals going bad.
Thanks everyone for the suggestions i gave up and had it towed to be looked at by a mechanic so far he has found no vacuum leak.next he is going to use a live data reader and see if anything pops up but first he has to fix my obd2 plug cuz it isn't getting a constant 12v.and i have already replaced the TPS,IAC Valve And EGR
