95 eclipse no start after repair
Old Feb 2, 2010 | 08:52 PM
rayzda's Avatar
Default 95 eclipse no start after repair
ok so im gonna try to keep this as detailed as possible
i own a 95 eclipse gs non turbo 5spd so i was driving to a friends house when the car started to act up the battery light came on so i shut it off and it did not start up so i had the car towed to my house i replaced the battery and altenator and now car wont start it cranks but no start i checked for spark but none at all i cant even hear the fuel pump turn on i am stuck and don't know what to do any info would help thanks. oh also would the ecm have to do with any of this i checked around for the ecu but i can not find the part number i need or correct one
Old Feb 2, 2010 | 09:06 PM
dsm1990gsx's Avatar
Check all your fuses.
Old Feb 2, 2010 | 10:41 PM
rayzda's Avatar
checked all fuses and all are good how can you tell if the ecm is bad
Old Feb 2, 2010 | 11:24 PM
3000gt16's Avatar
Okay so all fuses are good, I assume that includes the relays on the firewall? If not, check those I had an issue with one of them, if so, a few things I would check in your position:
~95 eclipse was obd2, get your hands on a reader maybe you can see if you cooked the ecu.
~check connections and wiring from the alternator.
~Check plugs/wires/coil if theyre old.
Again, not guaranteeing a in any of those, just what I would be checking out. When mine randomly stopped turning over I noticed one of the relays was toast, ironically right after doing plugs and wires, and at the same time my battery quit on me. I checked all through those.
Hope anything in that helps.
Old Feb 3, 2010 | 12:28 AM
rayzda's Avatar
yea i have a obd2 scanner and checked for codes nothing also i replaced the spark plugs along with the valve cover gasket and thermostat and upper rad hose checked all connections to the new altenator but did not check the relays i think 2 are mounted on the firewall next to the master cylinder if im not mistaken but i will recheck everything tomorow and go from there by the way what are the 2 relays for on the firewall
Old Feb 3, 2010 | 04:54 PM
rayzda's Avatar
so today i rechecked everything and all was good until i got back to the ecu so i unplug the ecu to check it but when i go to but it back the fan, fuel pump and all relays start to click then stop only when i play with the ecu does this happen but when its pluged in all the way i get nothing only when i play with the ecu connection everything starts to click (relays) but then stops when i put the connecter all the way in i really dont know wats going on maybe the ecu is faulty some one please help im stuck
Old Feb 5, 2010 | 10:02 PM
rayzda's Avatar
any other help please
Old Feb 8, 2010 | 08:00 PM
rayzda's Avatar
help sos
Old Feb 10, 2010 | 11:46 PM
3000gt16's Avatar
I believe the relays on the firewall are related to starting, but notpositive, I can check the book tomorrow. As to the ecu thing, Im guessing theres a bad connection/broken wire that as you move it around youre losing and gaining connection to that certain wire. My gf's nissan sentra has anissue with the positive battery cable, that itll randomly break connection so when you try to turn it over again it may not work, you gotta fiddle with it to get the connection again.
Again Ill look into the relays thing in the morning. Hope youre havin some kinda luck
Old Feb 11, 2010 | 09:36 PM
rayzda's Avatar
thanks man this car is kicking me in the but haven't drove the car since and i need it back on the road
mysticrythms
Mar 19, 2014 08:17 PM
MiriamPoppe24
Oct 6, 2013 07:16 AM
Gwinter
May 21, 2013 02:35 AM
dahoopd
Nov 4, 2010 08:10 PM
jdr1234
Jul 2, 2008 10:35 PM
