95 gst not starting
Old Aug 20, 2008 | 02:30 AM
modkilla9's Avatar
Default 95 gst not starting
hey i have a 95 gst 5 speed and its not starting it turns over but will not fire ive read other forume about the temp sensor not letting it start but i also got the car from a junk yard so i have no idea wut is wrong with it i hooked the computer diagnostics to it and it read crank sensor but i dont want to spend the money on it if thats not the problem so if anyone has anysuggestions for me please let me know thanks
Old Aug 20, 2008 | 08:04 AM
Default RE: 95 gst not starting
Check for spark, and also check the timing belt and make sure that it is timed correctly
Old Aug 20, 2008 | 08:10 AM
sk8dudety's Avatar
ea man check the little things first before you jump into a big project... it could be plugs, wires, starter, ect... check it all out first
Old Sep 1, 2008 | 11:09 PM
modkilla9's Avatar
ive checked all that ive been workin on the car for overa year the obd2 told me it was the crank but i was just checkin around if other **** can pop out that code
Old Sep 2, 2008 | 09:19 AM
jerusry's Avatar
well, if it tells you it is the crank sensor. i would assume it may be that. that could cause it not to start... if i were you i would check the wiring before and after the sensor to see if it is bad before the sensor or if the sensor itself is bad. if it is bad... replace it... pretty simple solution if it is bad before the sensor... sart tracing the wires to the culprit.. and it is not worth it to give up on a project because of something like that... maybe if you found out the internals were mush.... but even then it would only give me the drive to build a monster. good luck with the car man. btw i would use an ohm/volt meter to check the electrical. it is a very simple and easy process.
Old Sep 3, 2008 | 10:54 PM
modkilla9's Avatar
well thanks man yeah i dont plan on giving up anytime soon i got a sleep as it is how many 93 clipses do u c with a 95 motor
Old Sep 5, 2008 | 03:17 AM
modkilla9's Avatar
so just for the hell of it i get some money and buy the sensor i go to put it on and then i relise that advance gave me the wrong part i am ****in pissed but then also i relise it is the crank sensor cause it is broken in to pieces so i have one last request im looking for a canadian hood for the 93 eclipse my frind had a 91 canadian addtion and it doesnt have the buble so if anyone has one or knows where i can get one please let me know thanks
Old Sep 5, 2008 | 03:41 AM
silvercoupe97's Avatar
Are you sure it's the crank sensor? That sensor is covered by the lower T-belt cover and behind the crank gear. Now the cam sensor is the one on the intake cam shaft/gear (closest to the intake). Is that the one that you're referring to?
mvoltage
Jul 31, 2014 03:34 AM
mazdaboi88
Sep 21, 2008 07:35 PM
50ul }{4ck3r
Jul 17, 2007 11:11 PM
bekahu410
Aug 20, 2005 12:34 AM
Nubian QT
Oct 9, 2003 12:09 PM
