95 gst questions
Old Dec 12, 2009 | 10:07 PM
iroccamero's Avatar
Default 95 gst questions
OK I'm working on my 95 gst when i accelerate and start to build boost i get alot of smoke out the exhaust
here are the list of mods done
16g turbo upgrade, 550cc injectors, walboro 255 fuel pump, 8.5mm spark plug wires
any help will be greatly appreciated and i will answer any questions i can
Old Dec 13, 2009 | 10:13 AM
byrdman4185's Avatar
is it black smoke or white smoke. if its black then you are running to rich. if its white then you prob have a piston ring that is failing. get a compression test done.
Old Dec 13, 2009 | 10:21 AM
iroccamero's Avatar
yes it is black i had done a compression test already and have 160 in all cylinders. so if its running rich how do i adjust that i thought the mixture is controlled by ecu
Old Dec 13, 2009 | 11:04 PM
iroccamero's Avatar
OK so i found a couple vacuum leaks and fixed them, now i have a different problem when I'm accelerating i have like a serging thing happening.
any thoughts
Old Dec 13, 2009 | 11:07 PM
dsm1990gsx's Avatar
Boost leak test.
Old Dec 17, 2009 | 10:08 AM
what are you using to tune. And how high boost are you running?
Old Dec 17, 2009 | 11:22 AM
iroccamero's Avatar
well when the problem started it was completely stock thats when i started replacing components hoping that it would fix the problems. i started with the turbo then went to fuel pump and then fuel rail and injectors i haven't been ably to get it running good enough to take and have it tuned and as far as the boost it still set at stock i haven't changed it
Old Dec 17, 2009 | 11:26 AM
iroccamero's Avatar
i also just boost checked it and found 5 leaks. the throttle body had 2 leaks the throttle shaft and the screw. the other leaks where in the tubing. now I'm waiting on the rebuild kit for the throttle body to see it that works.
Old Dec 19, 2009 | 09:02 PM
iroccamero's Avatar
OK so i just got done rebuilding my throttle body to fix the leaks. i have no leaks now but still have the surging thing happening any other thoughts
caseclipsegst
Aug 18, 2009 08:54 AM
ridingDSM0201
Jun 15, 2008 05:14 AM
posey27
Feb 27, 2008 05:18 PM
seawolfxix
Feb 10, 2006 06:41 PM
98GstSpyder
Jun 10, 2004 11:11 AM
