95's
Old Jun 25, 2007 | 01:48 PM
theinnereffect's Avatar
Default 95's
me and a friend of mine both recently got 95's one is a gst and the other is a gsx I was wondering what things should I change and how often to avoid any problems like how often do u guys change the oil for example or timing belts things like that i figure it should be about the same for both since they have the same engine well let me know guys thanks
Old Jun 25, 2007 | 02:04 PM
I Drive Naked's Avatar
Default RE: 95's
change the oil every 3,000 (I g every 4k b/c I use Mobil 1 sunthetic).
Timing belt evert 60k, service coolant 30k, plugs/wires 30k, tranny/t-case/rear diff every 60k.
Also, check all your belts and hoses for cracks/peeling/etc.
Being as you both have 95's, I assume you have the 7 bolt motor.
Its notorious for a rather unavoidable problem called crankwalk.
Search the term and you'll learn all about it.
Old Jun 25, 2007 | 02:11 PM
Default RE: 95's
ok thanks
Old Jun 26, 2007 | 03:04 PM
TSG59_Steve's Avatar
Default RE: 95's
Also check your brake pads, bushings on the suspension (jack the car up and jerk the wheel around a little bit), I'd suggest taking out your axles every30k because they are known to seize into the wheel bearing = new spindle/hub/and wheelbearing, And by take them out I mean just get them loose and if any boots are torn/leaking replace them, also chg your tranny fluid every 60k at least... that's about all I can think of right now. Also make one of these: http://www.vfaq.com/mods/ICtester.html
