96 Eclipse Engine Speeding
Old Nov 4, 2006 | 05:16 PM
rlbrlb's Avatar
Default 96 Eclipse Engine Speeding
I have a 96 Eclipse, new motor from Recon. in approximately 4 months. Running great, but my son had trouble eith engine speeding. He was in second gear ready to shift to third and the engine speed stayed high with foot off gas pedal (not stuck by floor mat). He pulled over and shut motor off, restarted and the engine speed took off again (6000 RPM). Could a TPS or ECU cause this?
Old Nov 4, 2006 | 09:45 PM
Default RE: 96 Eclipse Engine Speeding
Clean out your throttle body.
Old Nov 6, 2006 | 09:23 AM
also check the throttle cable to make sure its not getting stuck either.
Old Nov 6, 2006 | 01:00 PM
N/Teclipse's Avatar
If the cable is fine I would also check the throttle positioning sensor.
Old Nov 7, 2006 | 10:25 PM
rlbrlb's Avatar
Thanks All !!! It appeared to be the Cruise control cable. Looked like the cable had been kinked and was hanging up at times.
Old Nov 8, 2006 | 10:05 AM
glad to hear you fixed it
Vizion
Dec 17, 2006 01:24 AM
XTREME
Nov 19, 2006 04:49 AM
dirtwagon
Sep 27, 2006 07:08 PM
schif_e
Jun 2, 2006 02:16 AM
nirv_ni_ana
Nov 9, 2005 07:06 PM
