96 eclipse gsx transmission problem
Old May 10, 2011 | 11:43 AM
eclipse120's Avatar
Default 96 eclipse gsx transmission problem
I bought this gsx awd turbo automatic with an engine problem so I went and bought a import dsm engine and transmission. After installation, the car wouldn't start. The import transmission had a different plug which let the computer know that the car is in park, therefore, starting. I tried to change the plug but i hear it's not possible. After that i went and bought an american version of the transmission and everything connect right. the engine started and when i went to put it on drive nothing happens. the car just seats and doesn't move regardless of which gear. I thought the trans was bad so i returned it, then recently i found another trans and install it. After all the hard work am having the same issue and i can't think that two transmissions are bad. Everything is connected properly and car starts but doesn't move, i don't have any check engine or any lights on the dash. Any suggestions or anything i should be looking at to help me fix this issue?
golfnbill
Jul 7, 2010 12:49 AM
Sheijin
Apr 30, 2007 02:15 AM
sickend
Nov 1, 2006 01:56 AM
DjCorkscrew
Mar 20, 2006 11:18 PM
fordmanturnedmitz
Oct 29, 2004 12:49 AM
