98 eclipse stock alarm starter problem (i will pay for a working answer!!!)
Old Feb 15, 2009 | 08:03 PM
fresh83's Avatar
Default 98 eclipse stock alarm starter problem (i will pay for a working answer!!!)
i have 98 GSX eclipse automatic, i was at the mall today , somehow the stock alarm started going off , i also have a aftermarket alarm on it to , the noise wouldnt stop and i dint know how to stop it so i started the car.
the car drove with the noise continuing until someone pulled up and told me to put the key in the drivers dooor, not thinking i turned the car off in drive on accident and had to put it back in park to get the key out .
i put the key in the door and it stoped the noise but when i went to start the car, nothing . it goes all the way but theres no clicking . ive done some research and it seems like the anti theft killed my starter , how do i fix this please this car is my only life line .
Old Feb 15, 2009 | 08:06 PM
fresh83's Avatar
Default RE: 98 eclipse stock alarm starter problem (i will pay for a working answer!!!)
Note:before this i wasnt haveing problems with the starter, my check engine light was on , but it was a p0505 idle speed control
Old Feb 15, 2009 | 08:40 PM
2slow's Avatar
when you say nothing what do you mean ??? no lights no start car cranks but no start . help me help you
Old Feb 15, 2009 | 08:46 PM
fresh83's Avatar
lights radio and alarm all work when i turn the key , it dosnt turn over . i havent had any problems with the starter before today either
Old Feb 15, 2009 | 08:58 PM
needsagst98's Avatar
try disconnecting your battery and then reconnecting it.?. have you tried that?
Old Feb 15, 2009 | 09:06 PM
fresh83's Avatar
yeahh tryed that ....its either the theft system or somehow the theft system blew out the starter or the starte solinoid ...it seems like im not the only person who has had this problem before , lookin for a fix before the dealer steals my whole paycheck for something that will probably be simple
Old Feb 15, 2009 | 09:44 PM
Try putting the key in the ON position, then holding the aftermarket alarm system bypass button (or whatever its called) then while holding, turn the key and see if its starts. I bet its your new system that is locking you out and not the stock one. If that doesnt work you are gonna need to try jumping a couple wires in your security system to bypass it
Old Feb 16, 2009 | 09:53 AM
fresh83's Avatar
well its at the dealership now and theyve been looking @ it for over a hour so im guessing they have no clue either.....thank you for that and any other solutions would be appreciated also
Old Feb 16, 2009 | 12:47 PM
remove both alarm systems or use the factory one.
fresh83
Feb 15, 2009 07:53 PM
XxM4n1aCxX
Oct 11, 2008 11:06 AM
winson
Apr 30, 2008 05:50 PM
msiminski
Aug 12, 2006 02:48 PM
Smejk
Feb 11, 2005 07:34 PM
