98 spyder gs leking oil need help
Old Jul 25, 2013 | 10:20 AM
jeff98's Avatar
Default 98 spyder gs leking oil need help
I have a 98 eclipse spyder gs 2.4L I have oil leaking from my Balance Shaft Tensioner How do i fix it or how much would it cost to get fixed?
Old Jul 25, 2013 | 02:58 PM
Akzle's Avatar
gasket. Or oil seal.
Eithr way youre taking the cover off.
Is it the shaft behind the oil pump?
Old Jul 25, 2013 | 09:00 PM
jeff98's Avatar
Not sure its the bottom left tensioner
Old Jul 25, 2013 | 10:50 PM
Akzle's Avatar
looks like the cambelt has hydraulic tensioner (that grey brown tube bit..?)
so... what's actually leaking? the blue circle bit? and how is it tensioned? looks like that rear belt does drive the oil pump? so the balance shaft is in behind it?
Old Jul 29, 2013 | 04:16 PM
jeff98's Avatar
Ya its the blue circle its leaking out the bottom of it. so what exactly is it? and is it an easy fix or should I take it in?
Old Jul 29, 2013 | 05:35 PM
Akzle's Avatar
its an idler pulley. Sealed unit, id be surprised if it had oil in it. Bolt on replacement easy enough.
ccernst
Jan 14, 2011 08:38 AM
Vadimus
Nov 26, 2010 12:13 PM
TheRock0720
Nov 12, 2010 12:30 PM
lancer0594
Feb 5, 2009 06:48 AM
hairbear65
Feb 1, 2009 09:35 AM
