99 Eclipse GST 2.0 Valve Cover Gasket Replacment
Old Aug 22, 2008 | 06:35 PM
Roberte's Avatar
Default 99 Eclipse GST 2.0 Valve Cover Gasket Replacment
What is the best approach to separating the valve cover from the head on a GST 2.0 so that I don't damage or fracture the aluminum surface on the head or the cover? I have all visual valve cover bolts and the spark plugs removed. I hear the cover loosening at the front, but sense that the gasket is sealed pretty well at both ends and at the back. Where would be my best leverage point? Thanks for your input.
Old Aug 22, 2008 | 06:39 PM
darknigh7th's Avatar
Default RE: 99 Eclipse GST 2.0 Valve Cover Gasket Replacment
when i took mine off i took the oil cap off and just pulled from inside there, took a bit of time but it eventually came off.
Old Aug 22, 2008 | 07:05 PM
you should be able to just take a flat head screw driver and pry up on a couple spots. The whole thing is pretty solid so just do it slowely little by little.
Old Aug 22, 2008 | 07:38 PM
Roberte's Avatar
Got it! Thank you!!
dopeysw20
Oct 12, 2011 09:06 PM
bcolins
15
Mar 31, 2010 11:55 AM
Natedogg89
Feb 17, 2007 07:49 PM
kyguard22
Jan 26, 2007 03:29 AM
butter03
Mar 23, 2006 06:10 PM
