Valve cover gasket, spark plugs, 97 GST
Old Feb 16, 2007 | 11:55 PM
Natedogg89's Avatar
Default Valve cover gasket, spark plugs, 97 GST
Whats all involved in changing the valve cover gasket on a 97 GST? It seems like it will be a pretty easy job but i thought i would ask. Also what should the valve cover bolts be torqued to? From what i have read they shouldn't be more than hand tight.... Also what are good spark plugs for a gst? Thanks
Old Feb 17, 2007 | 12:34 AM
silvercoupe97's Avatar
Default RE: Valve cover gasket, spark plugs, 97 GST
Yes, it's an easy job. There's really nothing to note. The torque was 14ft lbs-15ft lbs on the outside bolts and 2.5ft lbs on the inside bolts, which is really light, don't even use a socket type torque wrench, instead use the needle type (nice technical names, eh). Hand tight is a good rule for these fragile valve gaskets and tighten a tad more if it's leaking.
Spark plugs, this was just talked about in another thread...DSMs are happy with NGK BP6ES or 7ES (1 step colder)
Old Feb 17, 2007 | 01:30 AM
Natedogg89's Avatar
Thanks!
Old Feb 17, 2007 | 01:32 AM
id stick with the bp6es plugs cuz i dont think youll need the 7
Old Feb 17, 2007 | 01:33 AM
agallardo's Avatar
14-15 LBS of torque? Thats alot! Is that right? You sure Silvercoupe97...?
Old Feb 17, 2007 | 01:39 AM
That is a lot, that's what my CD manual calls for. I don't do valve covers with a torque wrench though, I prefer hand tight + a quarter turn, lol. I think I told you somewhere around 10-14ft lbs. I don't remember though.
Old Feb 17, 2007 | 01:44 AM
agallardo's Avatar
lbs of torque? or inches?
Old Feb 17, 2007 | 04:44 AM
Ft lbs, inch lbs value usually seems high because it's usually double what Ft lbs are.
I'm sure you meant Ft lbs vs. Inch lbs
Old Feb 17, 2007 | 12:18 PM
1 ft-lbs = 12 in-lbs
Old Feb 17, 2007 | 07:49 PM
It's almost automatic for me to convert that in my head, isn't it for y'all? It's just basic math..so now, when I see 168in lbs on a page, I'm thinking the math, lol. Then there's NM...nm x .74 = ft lbs.
Torque
foot-pounds(ft-lbs) into Newton-metres(Nm) ft/lbs x 1,35 = Nm
Newton-metres(Nm) into foot-pounds(ft-lbs) Nm x 0,74 = ft/lbs
Newton-metres(Nm) into kilopond/cm²(kp/cm²) Nm x 0,102 = kp/cm²
cwilson01
21
May 28, 2019 08:03 AM
theor23
Apr 17, 2014 02:39 PM
bcolins
15
Mar 31, 2010 11:55 AM
Roberte
Aug 22, 2008 07:38 PM
butter03
Mar 23, 2006 06:10 PM
