99 eclipse no start
Old Jun 12, 2005 | 12:40 PM
cog1's Avatar
Default 99 eclipse no start
Hi we have a 99 eclipse, 2.0 non-turbo, just put a rebuilt engine in it but it has no spark. Checked voltage to cam sensor and crank sensor, they are low, does that sound like a PCM problem? Any ideas are appreciated!
Old Jun 13, 2005 | 12:26 AM
Sanguinius's Avatar
Default RE: 99 eclipse no start
It has no spark where?? Just at the plugs or at the distributor or the coil? If you have no spark why are you looking at sensors?? If the sensors were bad it MIGHT cause no spark but I'd be checking the obvious first being the ignition system rather than looking at the obscure areas of sensors. Those aren't NEARLY as likely to go bad as something like a distributor cap or rotor.
Old Jun 13, 2005 | 11:00 AM
cog1's Avatar
No spark to plugs, no power to coil, it is a distributorless ignition system
Old Jun 13, 2005 | 03:24 PM
Sanguinius's Avatar
Oh yeah LOL sorry forgot these are distributorles systems (I'm bustin my brain trying to figure out an '82 BMW that doesn't want to play). In that case I'd suggest looking at a wiring schematic and flipping through either a Chilton's or a manufacturer's repair manual to get the voltage specs on a few things and see where the sensors actually go. I thought that cam and crank pos sensors actually ran right to the ECO not the PCM. I could be wrong but that was my impression.
Old Jun 13, 2005 | 05:05 PM
get435's Avatar
I thought all the wires should got to the pcm because it is a relay center for the ecm.
Old Jun 22, 2005 | 11:17 AM
cog1's Avatar
PCM was fried[:'(], replaced and it runs great now, thanks for everyone's help!!!
mysticrythms
Mar 19, 2014 08:17 PM
dahoopd
Nov 4, 2010 08:10 PM
matt_75
1st Generation
Sep 12, 2005 01:11 PM
laceyEclipse01
May 10, 2004 10:39 PM
TNAQ420
Jun 7, 2003 10:59 AM
