99 GST not starting/running
i have a 99 GST that has kind of a dual problem. It will either not start or start and run for 30 seconds then turn off. I checked the fuel, spark, and checked for codes but i found no problems. I really need some advice on any other systems or parts could cause a problem like this!!!! Also: This is a manual trans vehicle that recently had its enging replaced
start with the compression test like he said. But what about checking the alternator. Have you tried jumping it and leaving it to let the battery charge. See how long you can get it to stay running while still on the jumper cables
