ABS problems
Old Jan 3, 2005 | 08:52 PM
97GS NORWAY's Avatar
Default ABS problems
After driving for a few minutes,my abs system stops functioning and the warninglight lights. Been to the local mitsubishi dealer,but they are not very helpful,since the eclipse is never sold in Norway and they don`t seem to know a dammn **** about the car..........The connections to the brakes seems to be ok,but where is the rest of the system located? I guess there must be a relay for the abs system somewhere......?
Old Jan 17, 2005 | 12:33 AM
customizedrides's Avatar
Default RE: ABS problems
It could be a lot of thihngs. Unfortunatly with a problem like that you have to have a wiring diagram and be good with a DMM. I would double check the connections at the wheels, they may be exposed soomewhere and shorting from moisture or the connection could be loose. Also unplug them and check for rust. The other thing you could do is check the ECU for any codes, that may be easiest. The relay for that is usually in the trunk or right under the hood. Good Luck!
Old Jan 17, 2005 | 08:13 PM
1398spdr's Avatar
and something easily overlooked is make sure you have enough brake fluid........
Old Jan 18, 2005 | 07:55 PM
Have had my ecu checked at local Mitsubishi dealer. They found an error code,but didn`t seem to hav a clue what it was about. The Eclipse has never been sold in Norway and they don`t have any data about it.[:@]
Old Jan 19, 2005 | 02:02 PM
1398spdr's Avatar
if you know what the code is you can most likely find it online somewhere..........
Old Jan 20, 2005 | 03:25 PM
vertstanggt's Avatar
Or try calling a dealership in the US, see if they might talk to you about it if you can't find it online.
Cosmin Alexander Marinescu
Jun 18, 2014 06:31 PM
jp2000
Jan 1, 2012 05:21 PM
fallingapart3000gt
May 13, 2006 01:35 PM
j22ame
Aug 21, 2005 05:54 PM
deadweasel101
Jul 6, 2004 03:02 PM
