AGAIN!! !!
Old Jun 21, 2007 | 06:15 AM
Default RE: AGAIN!!
I still agree with them. Start with the Throttle body first. Clean the inside with carb cleaner. While doing that, check the coil on the back side of the TB. Maybe spray it with some WD-40. If you still have the high idle after this then start check some of the other things. But is this a non turbo or turbo. If its a turbo then the next thing id do is the BISS. Here is a link http://members.shaw.ca/dsm.1000q/Eng...er/1G/biss.htm
Old Jun 21, 2007 | 06:44 AM
lycan84's Avatar
Default RE: AGAIN!!
my car is a 5 speed non-turbo im just a sad 420a
Old Jun 21, 2007 | 06:48 PM
silvercoupe97's Avatar
Default RE: AGAIN!!
If I remember correctly my 6g73 didn't have a BISS screw but it had a throttle pulley screw that adjusted idle, the 420a should be about the same.
Old Jun 22, 2007 | 07:00 AM
lycan84's Avatar
Default RE: AGAIN!!
see the thing about this is it does it sparaticly its not all the time. usualy after hard driving
Old Jun 22, 2007 | 11:43 AM
Default RE: AGAIN!!
ECU is my guess
Old Jun 22, 2007 | 12:34 PM
lycan84's Avatar
Default RE: AGAIN!!
so just disconect the battery for like 10 mins. or so?
Old Jun 22, 2007 | 12:47 PM
Default RE: AGAIN!!
My guess is that its ****ed
Old Jun 22, 2007 | 01:17 PM
lycan84's Avatar
Default RE: AGAIN!!
i sure as hell hope not
Old Jun 22, 2007 | 01:36 PM
Default RE: AGAIN!!
Might be a wire harness or something. Its almost impossible to tell
Old Jun 22, 2007 | 01:59 PM
lycan84's Avatar
Default RE: AGAIN!!
i just disconected the battery ill check the TB
