AGAIN!! !!
Old Jun 22, 2007 | 02:00 PM
  #21
Default RE: AGAIN!!
okay. Put the key in the ignition to drain any excess power You would be suprised.. there is still enough power to light up the dash for a split second
Old Jun 22, 2007 | 02:06 PM
  #22
lycan84's Avatar
Default RE: AGAIN!!
did that saw no light. butterfly valve (throttle valve?) in intake is squeeky clean, ive been playing with all the connectors that i can find making sure they are tight.
Old Jun 22, 2007 | 02:14 PM
  #23
Default RE: AGAIN!!
Your on the right track. All it takes is one wire that is loose on a wire harness
Old Jun 22, 2007 | 02:16 PM
  #24
lycan84's Avatar
Default RE: AGAIN!!
nothing is loose either. i hope to god its just the ecu needed to be reset because this could turn out to be a major PITA if i cant figure it out.
Old Jun 22, 2007 | 02:48 PM
  #25
Kaede.Noir's Avatar
Default RE: AGAIN!!
I might be a lil late, but for the injector cleaner a throughly good metod is getting an otc canister cleaner, and do it with seafom, its gonna be WAYYYY rough, a very bad idle, but after a while its gonna be all better (it goes so rough it actually scared me, damn thing is so violent.)
Old Jun 22, 2007 | 03:40 PM
  #26
lycan84's Avatar
Default RE: AGAIN!!
you guys are going to either hate me or think im just crazy becuase I bought a POS which im starting to regret. Okay after disconnecting the battery for a while i went to start it, it turned over but died immediatly. then i started her up again and she ran great smooth idle no problems. about 45 mins later when i put the clutch in to stop IT DIES!!! i had to fight it the whole way home pop started it once just to keep up with traffic. now what??? besides sell it.
Old Jun 22, 2007 | 05:57 PM
  #27
silvercoupe97's Avatar
Default RE: AGAIN!!
Give the ECU a little bit to relearn the sensors. Remember, you just reset it.
Old Jun 22, 2007 | 06:02 PM
  #28
Default RE: AGAIN!!
^^ hes right
Old Jun 22, 2007 | 08:56 PM
  #29
lycan84's Avatar
Default RE: AGAIN!!
okay
Old Jun 23, 2007 | 03:09 AM
  #30
lycan84's Avatar
Default RE: AGAIN!!
well she did alright seeing as how i actually did go to my house finally several hours later, only died like once with clutch in. it started to but then didnt another time i will keep yall updated with the black POS. it sucks to make payments on something that runs when it feels like it.
