Almost done with swap. Need a little help
Old Dec 7, 2006 | 09:11 PM
5Tizzle's Avatar
Default Almost done with swap. Need a little help
I went to the magnus website and the diagrams they have for the cam sensor, dont have the same color wire as the one im using. I made this crappy picture to show you how its hooked up. Is this right?
Where does this hook up to? its hooked on to the oil cooler, and just hangs down.
This one is on the left side of the motor. Dont know where it goes at all...
Dont know where this goes either...It only has one wire coming out of it, and its also on the left side of the motor.
Are these turbo coolant lines hooked up right?
Where am i supposed to hook this up to?
Old Dec 7, 2006 | 09:20 PM
5Tizzle's Avatar
Default RE: Almost done with swap. Need a little help
Oh yeah and this...do i have to plug this into anything? Nothing like it was on my 2g thermostat housing...
Old Dec 7, 2006 | 09:50 PM
silvercoupe97's Avatar
Pic #2 is either the pressure sender wire or the dummy light wire.
Do you have cruise installed too (referrencing the plugs on the passenger side)?
I haven't seen my turbo lines in awhile, so I can't help there[>:]
The last post, you do need to connect that temp sender, it goes to the ECU and turns on the coolant/A/C fan.
Old Dec 7, 2006 | 09:51 PM
ORIGINAL: Jeffisdecentttttt
Is your knock sensor plugged in?
Old Dec 7, 2006 | 09:58 PM
5Tizzle's Avatar
uh. i dont know? where is the knock sensor? do you know if my wiring is right on the cam sensor?
Old Dec 7, 2006 | 10:15 PM
Sanguinius's Avatar
Your last pic is of the temp vaccuum control valve. It senses the temp of the coolant and adjusts the vaccuum for EGR purposes. If there is no EGR system then don't hook it up to anything
Also something else for you Jeff, Take pics a little farther away (Gives us a better idea of EXACTLY where and what the plugs you're asking about are located), and then use paint or photoshop or something to just circle the items in question in a bold vibrant color to point them out to us.
Old Dec 7, 2006 | 11:14 PM
5Tizzle's Avatar
ORIGINAL: Sanguinius
Thanks.
Do YOU know if my wiring is corret on the cam sensor?
Old Dec 8, 2006 | 05:16 AM
5Tizzle's Avatar
wont start. I think i left the knock sensor on my 7 bolt...Will the car not turn on without the knock sensor? Im not getting fuel or spark...
Old Dec 8, 2006 | 09:19 PM
5Tizzle's Avatar
update:
SHE RUNS
The problem was on the wiring for the cam sensor. If you look on this picture, i had the power and the ground backwards(black/red)
Ill post some videos later of how she sounds now, and of that noise it was making before i started the swap(loose rod bearing)
Old Dec 8, 2006 | 09:52 PM
2nd g eclipse gst's Avatar
congrats man!!!
