another little problem
Old Jun 28, 2007 | 10:33 AM
bestwiseguy's Avatar
Default RE: another little problem
ill run a boost leak test when i get off work today to see if that is my problem. just though it ironic that it started happening right after i changed spark plugs. it was minor before i changed them and after it does it alot worse.
[align=left] [/align]
Old Jun 28, 2007 | 10:50 AM
estraw's Avatar
check your fuel filter too.
Old Jun 28, 2007 | 11:42 AM
fuel filter has already been changed. it was changed when i had a tune up about 2 months back.
Old Jun 28, 2007 | 02:20 PM
TSG59_Steve's Avatar
What do you have the plugs gapped at? Should be .028.
Old Jun 28, 2007 | 04:37 PM
i have plain ngk plugs in there. from my understanding they come pre gapped. but i will check
Old Jun 28, 2007 | 04:47 PM
atown420's Avatar
i thought you always had to gap your plugs?
Old Jun 28, 2007 | 04:57 PM
we put my frinds plugs in his gsx the same day, used the same plugs and did not gap them. his is running perfectly fine. so im assuming they are pre gapped. but like i sayed i could be wrong.
Old Jun 29, 2007 | 09:03 AM
They do usually come pre gapped, but your problem sounds like it could possibly be misgapped plugs. Have you checked it yet? I always check them, most of the time they are in spec but there's been once or twice they were out of spec.
Old Jun 29, 2007 | 09:27 AM
no i didnt check them, should have though. ill check them today and let yall know.
Old Jun 29, 2007 | 10:59 PM
just an update.i checked the gap on the plugs today and they were off by about eight. they should have been gapped at around 30-32 and it was more like 40. igapped them correctly and now the car runs like a champ, for now.
