another problem!!!
RE: another problem!!!
When you turn on your AC it engages the compressor and it takes a lot of power and gas to run that thing. This is normal on EVERY car with an AC.And if you are really overboosting (what psi btw?), you might want to check your lines for your mbc. Make sure the right hoses are hooked up to the wastegate actuator and a boost source. Hope that helps.
