another problem!!!
Old Jun 18, 2007 | 03:36 PM
Dusty Eclipse's Avatar
Default RE: another problem!!!
The performance is the same... and the price is better... Home Depot.
Old Jun 18, 2007 | 03:40 PM
Slowboyracing has a good selection
Old Jun 18, 2007 | 10:08 PM
2nd g eclipse gst's Avatar
ight, thanks guys.... now something else, when i turn on my ac it takes alot of power away from the car and it barely wants to accelarate, why??
Old Jun 18, 2007 | 10:36 PM
boost leak?
Old Jun 19, 2007 | 03:40 PM
Gregory's Avatar
When you turn on your AC it engages the compressor and it takes a lot of power and gas to run that thing. This is normal on EVERY car with an AC.And if you are really overboosting (what psi btw?), you might want to check your lines for your mbc. Make sure the right hoses are hooked up to the wastegate actuator and a boost source. Hope that helps.
Old Jun 20, 2007 | 08:01 AM
RCJr9186's Avatar
how much boost are you running? i know you can't be running that much out of the 16g b/c you don't have supporting mods.
Old Jun 20, 2007 | 09:05 AM
50ul }{4ck3r's Avatar
I third HOME DEPOT....
darknigh7th
Feb 8, 2011 02:41 AM
BrunoBoy650
Mar 23, 2007 12:26 PM
burnmyeyes
Nov 1, 2006 01:27 AM
darknigh7th
Jul 16, 2006 08:57 AM
BrunoBoy650
1st Generation
19
May 9, 2006 05:34 AM
