Anti Freeze Question
Old Sep 27, 2005 | 05:03 AM
GreddyBooster's Avatar
Default Anti Freeze Question
Does anyone know what anti freeze color comes with a 99 Eclipse GS from factory
Old Sep 27, 2005 | 10:39 AM
get435's Avatar
Default RE: Anti Freeze Question
should be green but make sure that it is the kind that is ok for aluminum.
Old Sep 27, 2005 | 11:51 AM
oh so its aluminum? and what if i put the red one? cause i just bougth a PRESTONE antifreeze
Old Sep 27, 2005 | 12:00 PM
get435's Avatar
well the radiator and head are aluminum so you need a antifreeze that is ok for it or you will get corousion in the water from the aluminum. open the cap is it green did you drain it? If you have green fluid than use a green antifreeze qualified for aluminum.
Old Sep 27, 2005 | 05:40 PM
Sanguinius's Avatar
Make sure you didn't swap regular green antifreeze with Dexcool. Supposedly they fixed the problem with Dexcool but it used to be that if you mixed Decool with the regular green antifreeze it would, after a period of time, turn into a goo that did nothing but clog the entire cooling system. Like I said though supposedly fixed that problem.
milliesdad
Oct 16, 2014 11:34 PM
marianomontero
Jun 4, 2014 02:05 PM
dannyc
Feb 12, 2010 12:26 PM
carlover626
Feb 5, 2007 08:58 PM
