Anyone please help!
Old Jul 9, 2006 | 08:39 PM
a2rht930's Avatar
Default Anyone please help!
This Clunking noise is BULLSH*@ Same ole same ole under acceleration and decel/brakes I get a clunk noise in the front right area in motor, Replace the rear, front and driverside with prothane, the passenger side is fine I took it out and put it back in to make sure, something in the drivetrain area?! anybody know ne good mechanics? any suggestions?
Old Jul 9, 2006 | 09:38 PM
ncyankeealva's Avatar
Default RE: Anyone please help!
Do you hear it during like first and second gear, or going over bumps? Is your car lowered?
Old Jul 9, 2006 | 09:56 PM
a2rht930's Avatar
yes the car is ghetto lowered, heated springs in the front, coil overs in the rear, and I hear the clunk in straight line driving and turns, and in any gear, at any rpm, the "clunk" happens only under accel or sometimes in decel and always when braking.
Old Jul 9, 2006 | 11:43 PM
TX97GST's Avatar
It may not apply here, but the same thing was happening to my truck. It was where the drive shaft connects to the tranny. One of the U's had broken. sorry I could point the part out, just not very technical with names.
Old Jul 9, 2006 | 11:51 PM
93eclipsegsx's Avatar
could be a tie-rod
Old Jul 10, 2006 | 09:52 AM
ORIGINAL: 93eclipsegsx
could be a tie-rod
something liek that would be my guess, if its doing it on turns also and not only when your going over bumps then its something in this area at least. take the tire off that its comming from and see if there is play in the tie rod
Old Jul 10, 2006 | 01:47 PM
eclipsed4u's Avatar
ORIGINAL: a2rht930
suspension related problem. with a not-so-nice lower job, you are probably destroying alot of suspension parts.
Old Jul 10, 2006 | 03:12 PM
a2rht930's Avatar
anyone got any more ideas no play in the tie rod????
Old Jul 10, 2006 | 04:37 PM
a2rht930's Avatar
yall suck no one told me to check the wheel lugs! that was the problem
Old Jul 10, 2006 | 07:27 PM
ORIGINAL: a2rht930
[:@] they shouldnt be loose anyways.
