awd conversion getting started
Old Aug 16, 2005 | 04:33 AM
baker_sk8er37's Avatar
Default awd conversion getting started
Ok i found most of the parts i need to start the conversion
Transmission
Transfer case
Front axles----------------
Drive shaft----------------
Exhaust
Fuel tank and shield-------
Rear subframe
Rear axles-----------------
Rear differential
Swaybar
Rear knuckles--------------
E-brake cables-------------
AWD Flywheel---------------
Recommended AWD Parts (In addition to the above)
AWD fuel tank connectors---------------------------------------------
AWD subframe rear bolts
AWD drive shaft and exhaust brackets (spot welded in the tunnel)-----
Entire AWD rear suspension assembly (all control arms)---------------
everything with the line is what i have i have about 500 saved for a tranny adn a transfer case if anyone know were i can get one help me out because this is going down!!!
tell me what you think
Old Aug 16, 2005 | 11:11 AM
Patrick's Avatar
Administrator
Default RE: awd conversion getting started
im sorry, youre turning what into an AWD car?
Old Aug 16, 2005 | 12:55 PM
My 95 eclipse gst
Old Aug 16, 2005 | 08:25 PM
MachVR4's Avatar
While you have the entire AWD rear suspension on the ground, you might as well upgrade all
the rubber bushings with polyurethane bushings.
Geoff
Ex-Mach V
I'm in the midst of turning an 89 Turbo Mirage into a 2.0 Turbo Mirage with 1G parts.
Best of luck !
Old Aug 17, 2005 | 01:00 AM
slow420a's Avatar
I dont think its possible but if you do this you are the man. Before you go cutting anything or taking things apart I suggest taht you go to dsmtuners.com or 2gnt.com and look this up. BTW dsmtraders.con great place to find that you need and conceptillusions.con is parthing out a 1g gsx all parts mint cond.
Old Aug 17, 2005 | 03:50 AM
i have everything but the tranny i decided to go with a shepard tranny but need a month to save up but it is possible and i know welding and cutting is required to get it done
Old Aug 17, 2005 | 11:50 AM
Gregory's Avatar
are you very experienced with this kind of conversion? have you considered just buying a gsx? sorry, what makes you wanna do this? good luck
Old Aug 17, 2005 | 12:13 PM
get435's Avatar
if he has the parts why buy a gsx? a little time about the same time he would have to be searching for a car and why buy some elses problems? Than have to fix what they screwed up or just didnt do.
Neco
Jun 26, 2012 09:38 AM
BoostNightRanger
1st Generation
26
Apr 22, 2007 02:29 AM
badass91hatch
Dec 16, 2005 02:37 PM
morbid
Sep 6, 2005 02:38 AM
baker_sk8er37
Aug 13, 2005 03:21 PM
