awd/fwd clutch/flywheel diff? amd clutch suggestions
Old Oct 28, 2007 | 09:51 PM
97spydergs's Avatar
Default awd/fwd clutch/flywheel diff? amd clutch suggestions
i was looking aroung on the net and found lots of flywheels and clutches for awd's and a significant amount less for fwd's. well what i was wondering what is the differances if any from the awd clutches and flywheels to the fwd flywheels. i know the main diff the 6/7bolt but is there any other than that?
Also i was looking into a diff clutch from oem. and was wondering what your suggestions were? i was thinking a stage 3 since it can hold the power i will be at by summer but still be smooth enough for a dd. i am running right around 260hp an 240flbs right now an when i swap the head an pistons will be at around 350hp and 300-310ftlbs on low boost.
in your experiance what are your suggestions?
Old Oct 28, 2007 | 10:11 PM
estraw's Avatar
Default RE: awd/fwd clutch/flywheel diff? amd clutch suggestions
i think they might be balanced differently, not sure about that tho. but if they are, and you put the AWD one on a FWD, your car will shake a lot
Old Oct 29, 2007 | 11:41 AM
ACT 2600 for the clutch.
The reason for the clutch being more is because there is more material.
Old Oct 29, 2007 | 12:15 PM
for the clutch there is NO difference between the fwd and awd for any 4g63 from 90-99.
Old Oct 29, 2007 | 02:14 PM
Typo.. i meant flywheel
ralliGVR4
Apr 27, 2008 11:34 AM
sk8dudety
Nov 12, 2007 10:37 AM
Sebba
Aug 26, 2007 07:47 PM
baker_sk8er37
Oct 14, 2006 10:38 PM
outlancer
Aug 9, 2004 06:07 PM
