bad burnout idea HELP
Old May 10, 2007 | 11:47 AM
thehintons06's Avatar
Default bad burnout idea HELP
hello and thanks for your input
alright i was driving around last saturday and i was in first gear at about 4k and decided to drop the clutch rev the engine and let the clutch fly to do a moving burn out well that was a bad idea . I broke the cv axel and somthing else. i fixed the cv axel with a new one from advanced but now the car just vibreats as soon as i trun it on , in neutral and the gears. i dont know what it could be. i was thinking the clutch but the car still drives and dosent slip. My girl frined talked to a mechanic on the phone and they said it might be my sway bar but i dont know how a sway bar would make so much vibration when im not even moving? so do you have any ideas? thank you
Old May 10, 2007 | 11:52 AM
Default RE: bad burnout idea HELP
does it go away when you turn at all?
Old May 10, 2007 | 12:05 PM
Dusty Eclipse's Avatar
Balance shaft? Maybe its coincidental?
Old May 10, 2007 | 01:54 PM
TheAdvocate's Avatar
When you turn it on?
If its not moving when its doing it, could be the motor mounts?
Old May 10, 2007 | 05:59 PM
jlh077464's Avatar
i was thinkin motor mounts myself.
Old May 10, 2007 | 06:59 PM
the car keeps doing it when i turn . when i was under there today the mounts did have cracks in them. any other ideas?
Old May 10, 2007 | 11:07 PM
I Drive Naked's Avatar
Sounds like when you slammed it, the sudden stress on the motor broke a mount.
Old May 11, 2007 | 12:09 AM
GSXEX Knubbe's Avatar
damd ... thats the last time im gonna do it.
Old May 11, 2007 | 12:31 PM
darknigh7th's Avatar
throw some PU mounts in there, they're not that expensive.
Old May 11, 2007 | 02:28 PM
50ul }{4ck3r's Avatar
ORIGINAL: darknigh7th
PU mounts are good ones to use...so dont cheap out
