Bad oil leak
Old Oct 16, 2007 | 12:31 PM
asphalt_pimp's Avatar
Default Bad oil leak
I have a 1996GS Eclipse and it seems to be leaking oil from the rear cam seal. What should I do, and is it even worth all the trouble to fix myself?
Old Oct 16, 2007 | 03:08 PM
nick_200321's Avatar
Default RE: Bad oil leak
uhhh really it might just be the valve cover... and thats only a few bux
Old Oct 16, 2007 | 10:45 PM
mxmikie's Avatar
no dont fix it its not worth it ..........just park it on the street and leave the keys in it
Old Oct 16, 2007 | 11:33 PM
bestwiseguy's Avatar
^^^ Are you kidding or are you actually serious. I agree with nick, just change the valve cover gasket and see if that solves the problem. It is extremely easy to replace and not expensive at all.
Old Oct 17, 2007 | 01:14 AM
antlip's Avatar
Remember when putting the valve cover back on dont over tighten the bolts. You dont need to get a 1/2 socket and crank them down. You will crack the cover and cause more oil leaks.
Old Oct 17, 2007 | 06:04 AM
yea, dido with antlip, i have cracked 2 valve covers from cranking them down too much.. is there a torque the should be set at, anyone know?
Old Oct 17, 2007 | 10:22 AM
Well I know its not the valve cover gasket. Oil is comming outwhere the rear crankshaft gasket is. So I think I will sell this car and search for a better one b/c everyone seems to know that the 420a motor sucks. Mabey stop leak will fix it for awhile until I sell it? Thank you for your replies!
Matt
Old Oct 17, 2007 | 10:30 AM
ok you go from saying its near the rear CAM to the CRANK. Which is it?
Old Oct 17, 2007 | 02:23 PM
Sorry, I meant the rear crankshaft.
Old Oct 17, 2007 | 03:09 PM
well im not sure on how to fix a crankshaft gasket, never had to do it before, but it should be that extremely bad..
tom stockman
Jul 28, 2011 09:54 PM
ccernst
Jan 14, 2011 08:38 AM
TheRock0720
Nov 12, 2010 12:30 PM
nawgee
Oct 20, 2008 06:24 AM
agallardo
Oct 1, 2006 02:07 AM
