Balance shaft?
Old Nov 26, 2010 | 03:18 PM
DaSiver's Avatar
Default Balance shaft?
Have a 97 Eclipse GSX. Doing a head gasket replacement. The Haynes book I have refers to aligning the balance shaft on the Turbo engine. Problem is, I don't have a balance shaft. The crank pulley has the balance shaft sprocket behind the timing sprocket. Any design change for this particular engine in 97?
Old Nov 26, 2010 | 09:21 PM
KaiserEclipse's Avatar
other than a different thrust bearing design for the 7 bolt block i cant think of any difference in that engine
Old Nov 27, 2010 | 12:08 PM
DaSiver's Avatar
Thanks. I think I've figured it out. After doing some research I found out that they sell balance shaft elimination kits. I never would have guessed.
agallardo
Jun 15, 2022 01:38 PM
racerx55
1st Generation
52
Dec 15, 2006 04:40 AM
n2daizo123
May 16, 2006 08:17 PM
93eclipsegsx
1st Generation
Mar 5, 2006 12:13 PM
EclipseGSRoadRacer
Oct 5, 2004 05:54 PM
