balance shafts
Old Jan 28, 2006 | 10:33 PM
petro4411's Avatar
Default balance shafts
why do they take them out when you build the motor?? and why did mitsu put them in??
Old Jan 29, 2006 | 04:31 AM
DSMTalonAWD51's Avatar
Default RE: balance shafts
they put them in to decrease vibration, if you take em out you will gain ~10hp, but more importantly you have one less belt to worry about, because if the balance shaft belt brakes it takes the timing belt with it
Old Jan 29, 2006 | 04:52 PM
petro4411's Avatar
that sounds logical enough --tanks for the info
Old Jan 29, 2006 | 10:45 PM
Sanguinius's Avatar
It's a comfort thing. They install a balance shaft and belt and it counterbalances the rotation of the crank and camshafts evening out the engine causing it not to shake as much and also extending the life of the motor mounts. If you plan on removing the balance shaft then install stronger motor mounts or you'll feel the vibration increase in the car itself.
mack29730
1st Generation
21
Sep 2, 2008 05:59 PM
dave284
Feb 25, 2008 09:30 AM
hatchetman9449
Jan 28, 2007 07:53 PM
fbmange1ofdeath
May 8, 2006 08:50 PM
zero
Jan 13, 2006 10:34 PM
