big problem with turbo what should i do?
Old Nov 1, 2005 | 05:19 PM
jerusry's Avatar
Default RE: big problem with turbo what should i do?
it is internally gated
Old Nov 1, 2005 | 05:48 PM
get435's Avatar
it might just be pointless to put the boost to 10psi the stock bov i beleve will not let the boost go past the stock 7-8psi correct me if i am wrong.
Old Nov 1, 2005 | 05:53 PM
jerusry's Avatar
well you are probably right.... i was just gonna tinker until i get my bov. and keep the boost low... but, really need to figure out the problem of the non compressor housing vacum line... and where to put my mbc since i dont have a compressor housing hookup... would it be a really bad idea to make my own hole?? i realy have know clue as to what to do right now.
Old Nov 1, 2005 | 07:21 PM
ORIGINAL: get435
Im sure it will go past 7-8PSI but it will just leak badly. The EVO stock BOV leaks over 16PSI my car pulls to 19PSI but by redline it tapers down to like 17PSI if I replace it I should spool and hold boost where I want it.
As far as where the MBC goes I am confussed becasue generally it is an easy mod to do.
Old Nov 1, 2005 | 08:05 PM
Sanguinius's Avatar
What's the little green dot on the top right of the turbo isn't that where the line SHOULD go in?
Old Nov 1, 2005 | 08:49 PM
jerusry's Avatar
it is like that turbo not exactly the same... it doesn't even have anything to show where it should be or anything. if i were to just make my own "hole" then it would fix the problem right? so if i did should i just put it where that is? and would that fix my boosting problem? even if i didn't have the mbc wouldn't the car keep the turbo boosting properly itself?? thanks to everyone who has responded thus far and will in the future...
Old Nov 2, 2005 | 12:22 AM
DSMTalonAWD51's Avatar
see that nipple coming off the shiny brass gate? put one end of the boost controller to that, and the other end you need to connect to the vacuum line near your bov.
Old Nov 2, 2005 | 03:28 AM
Sanguinius's Avatar
That's about what I thought but being that I haven't much turbo experience I wasn't gonna jump out and say it myself.
Old Nov 2, 2005 | 04:12 AM
jerusry's Avatar
which vaccum line near the bov? do you have maybe a quick sketech or a picture of it? also, what do i do about the wastegate solenoid valve what do i connect to that? or should i block it off? cuz i have the vaccum going from the actuator to the solenoid... then back in the intake... but for starters... which vaccum line near the bov? what does it connect to. thanks for the help.
Old Nov 2, 2005 | 09:52 PM
jerusry's Avatar
plz help guyz.... i am in dire need.. my car is so close to right and i ahve not been driving it for 2 months cuz it ran bad and i had to get a new turbo... i am so close and so desperate!!!!!!! i am goin crazy!!!
