big problem with turbo what should i do?
well you are probably right.... i was just gonna tinker until i get my bov. and keep the boost low... but, really need to figure out the problem of the non compressor housing vacum line... and where to put my mbc since i dont have a compressor housing hookup... would it be a really bad idea to make my own hole?? i realy have know clue as to what to do right now.
ORIGINAL: get435
it might just be pointless to put the boost to 10psi the stock bov i beleve will not let the boost go past the stock 7-8psi correct me if i am wrong.
As far as where the MBC goes I am confussed becasue generally it is an easy mod to do.
it is like that turbo not exactly the same... it doesn't even have anything to show where it should be or anything. if i were to just make my own "hole" then it would fix the problem right? so if i did should i just put it where that is? and would that fix my boosting problem? even if i didn't have the mbc wouldn't the car keep the turbo boosting properly itself?? thanks to everyone who has responded thus far and will in the future...
which vaccum line near the bov? do you have maybe a quick sketech or a picture of it? also, what do i do about the wastegate solenoid valve what do i connect to that? or should i block it off? cuz i have the vaccum going from the actuator to the solenoid... then back in the intake... but for starters... which vaccum line near the bov? what does it connect to. thanks for the help.
plz help guyz.... i am in dire need.. my car is so close to right and i ahve not been driving it for 2 months cuz it ran bad and i had to get a new turbo... i am so close and so desperate!!!!!!! i am goin crazy!!!
