blinking engine light
Old Apr 21, 2007 | 03:48 PM
danderson's Avatar
Default blinking engine light
When the car is in accessory mode the engine light blinks and I can not figure out what this means ?!? I am having some oyher problems with the car just dying for no reason but I am not sure if this has anything to do with it. Pleeez help !!
Old Apr 21, 2007 | 03:56 PM
Default RE: blinking engine light
What kind of gas are you putting in?
Actually its a missfire. Fairly sure. Go to the stealership and get some spark plug wires. Replace your spark plugs with good old fashioned NGK plugs. None of that iridium ****.
Old Apr 21, 2007 | 08:05 PM
If you have a CEL then take it to the nearest Autozone and have them give you the codes from it. That will tell you your problem
Old Apr 22, 2007 | 12:59 AM
It sounds just like a missfire dude. Thats exactly how it would behave. Other than that the only thing i can think of is extreme knock.. and the missfire is a little more likely.
ole
19
Jun 10, 2015 10:47 AM
Nubiebubie_GSX
Aug 7, 2006 02:14 PM
ssmoore11
Jul 15, 2006 01:17 AM
ole
Jun 17, 2006 08:07 PM
Bop
Jun 2, 2006 08:07 PM
