Block off plate
Old Feb 26, 2007 | 08:22 PM
  #21
Manybrews's Avatar
Default RE: Block off plate
ORIGINAL: DBIGGS
wat is NOX
Oxides of nitrogen.
the main ingredient in the creation of photochemical smog. so disabling an EGR help people create THIS
see this link.
http://www.epa.gov/air/urbanair/nox/what.html
Old Feb 26, 2007 | 09:02 PM
  #22
RCJr9186's Avatar
yea, we all know about it but nobody does anything about it. instead we are talking about how to put on bigger turbo's to make our air even worse lol
Old Feb 26, 2007 | 10:52 PM
  #23
DBIGGS's Avatar
so, okay one last question when a person, like "RCjr" I have an egr block off valve, does that mean he had one on his car and put an aftermarket one on or does it mean he didn't have one at all and decided to put one on. Basicaly does a block off plate (valve) come with every car or do yo have to install one.
Old Feb 26, 2007 | 11:03 PM
  #24
silvercoupe97's Avatar
ORIGINAL: DBIGGS
It's something you install. Doing so removes the EGR from the equation. You'll also have to remove the vacuum line(s) going into the EGR system or you will have an hg (vacuum lingo) leak.
Old Feb 26, 2007 | 11:23 PM
  #25
DBIGGS's Avatar
so simply put:
block off plate, no recirculate exhasut into atmosphere
and block off valve, recirculate NOX into air and get icture above /\^/\
i'm so confused [&:][:'(]
Old Feb 26, 2007 | 11:50 PM
  #26
No...
Block off plate is what goes in place of where the EGR would normally recirculate exhaust gases back into the engine. So simply put
block off plate = no EGR valve
Old Feb 27, 2007 | 12:52 AM
  #27
DSMTalonAWD51's Avatar
ORIGINAL: Manybrews
not sure where you got that but of info, but Im afraid high combustion temps do not in fact make your engine more efficient. All that does is cause detonation, and eventually melted pistons.
I am not trying to carry on an argument here, but this is an extremely basic concept. High compression = highcombustion temps= more work per stroke performed by your motor. Its the whole idea behind why honda motors are so efficient, and also why they have a harder time passing the NOx portion of the smog test, lots of the older ones fail, they dont even have EGRs.Diesel motors, same idea, extremely high compression, like 20:1, extremely high heat, very efficient.
Old Feb 27, 2007 | 10:23 AM
  #28
DBIGGS's Avatar
oooooo ok I am satisfied now and I think I won't even touch the valve now. Just leave it alone.
cobamnator
Jun 13, 2011 11:48 AM
dorian7
Jan 22, 2008 06:09 PM
ttenn
Jun 10, 2006 01:45 AM
92_laser
Nov 10, 2005 06:47 PM
mitsu4x4nuts
Oct 16, 2005 04:08 PM
