blown head gasket
Old Jul 19, 2009 | 05:08 PM
dsm1990gsx's Avatar
If you find anything post some pics!
Old Jul 20, 2009 | 10:08 PM
spyderSAM's Avatar
Pulled the valve cover and everything looked and checked out fine. What was in the oil pan was a different story. Had a good bit of metal shavings laying in it. The rod bearing furtherest from the timing belt could be wiggled to produce the knocking sound thats been heard. SPUN ROD BEARING!
Now I need to figure out what im going to do with the thing. I was told I could replace the bearing as long as the crank and rods still looked good? If that can be done anyone know if it would last or be a wasted effort? I cant really afford a rebuild and nobody I know wants to help pull the engine. Im very low on options.
Old Jul 21, 2009 | 11:54 AM
dsm1990gsx's Avatar
Can you post pics of the meatal in your oil pan? If the crank and rod journals look good you might be able to get away w/ throwing a set of bearings. How long it would last like that depends on how much metal you have and how much damage was done.
Old Jul 22, 2009 | 04:59 AM
spyderSAM's Avatar
no pics of the metal. Depending if my dude flushed the pan out I might be able to try and get some when I head back over. There seemed like alot but then again I dont know considering Ive never dealt with anything like this before. There were shavings caught in the oil pick up screen thing but when the oil was drained it came out clean as a whistle. I honestly dont think the damage was that bad since I caught it really early and only had it knocking to diagnose (probably 5-10mins total).
Completely forgot that when we had it idling I was getting a little white smoke that I thought was the head gasket. Had no coolant in the oil at all though and it didnt shoot any out the exhaust. Only had some water drops collecting inside the exhaust tip? When revved the smoke got worse.
So whats white smoke with no coolant shooting out??? Turbo??? Dont want to pull the head if I dont have to.
Old Jul 22, 2009 | 06:44 AM
dsm1990gsx's Avatar
Is your car using coolant? Try doing a compression test.
Old Jul 22, 2009 | 11:12 AM
hmmm...i wonder if this is a case of the crankwalk. You may want to check for play in the crankshaft because you may have more of a problem then just the bearings.
Old Jul 22, 2009 | 04:05 PM
spyderSAM's Avatar
Might have a coolant issue not but sure. Just idling a couple mins and the head got real hot. Felt hotter than it should have. Coolant is still full though, Im not leaking? Got a small drip at the neck by the cap but thats it.
I keep pushing for my friend to do a compression test but for some he reason wont. Offered to help me out and then is being lazy, makes me angry because I cant do it myself. Kept saying there would be no point since we already know the bearings jacked up. So I went a ahead and ordered a set of bearings.
Ill be over there tomorrow so Ill check everything I can switch the bearings and hopefully then can get him to do a comp. test. What would I check for crankwalk???
Any other checks I could do?
Im going to have to get it home soon since its not in my garage. . .
Old Jul 22, 2009 | 05:39 PM
dsm1990gsx's Avatar
If you want more info on crankwalk I believe there is a lot of info on www.vfaq.com.
Old Jul 22, 2009 | 06:50 PM
like i said, check the crankshaft end play
Old Jul 22, 2009 | 06:55 PM
dsm1990gsx's Avatar
He was asking how to check it, I believe someone did a write on how to check for crank walk on vfaq.
