++ Boost ++
Old Apr 5, 2006 | 09:57 PM
ncyankeealva's Avatar
Default ++ Boost ++
Alright... I want to boost my car... I would like to do it the cheapist way possible without having a lot of problems. What would I need for a moderate turbo charge? And what can I use off another eclipse. I got a 2.4L 98, I know the manifold will bolt up... what else could i use?
Old Apr 5, 2006 | 10:08 PM
slow420a's Avatar
Default RE: ++ Boost ++
down pipe, rear exaust off a gst. smic, bov, ic piping, you would need to get a oil line kit though, and I would recomend getting a 16g with the waste gate set at 10 psi to start. you will also need a fuel system I recomend getting a sfmu ss hose kit setup w/ return line and a fuel press gauge either inline or in cab. Also injectors for running over 10 psi, safc to controle them, a 225lph walbro... that should be about it, you may need a new clutch after all of that and some abuse but taht should have you sitting pretty.
Old Apr 6, 2006 | 12:34 AM
if you go cheap you will break the car... boosting is never cheap unless you cut corners
Old Apr 6, 2006 | 01:04 AM
eclipsed4u's Avatar
ORIGINAL: EMonz57
and you will eventually spend more money on the repairs than if you would have just done it right the first time.
Old Apr 6, 2006 | 10:56 AM
skyline's Avatar
ORIGINAL: EMonz57
That's very true..............U should save up and buy a kit speificly made for ur car.........because they will have been tested and will have solid dyno numbers for u.
Old Apr 6, 2006 | 02:33 PM
slow420a's Avatar
that and a pre desgined fuel system and fcd
Old Apr 6, 2006 | 03:07 PM
Yeah, i want to boost... but i dont want to mess anything up... So I might just save up for a kit then...
Old Apr 7, 2006 | 12:28 AM
yea putting i a turbo is never a cheap thing. Either save up for a turbo kit or save up for a turbo car
anko_kun
Dec 24, 2006 07:48 PM
T76 turbo
Apr 16, 2004 04:53 PM
T76 turbo
Apr 15, 2004 01:02 AM
Pinser555
Mar 5, 2004 10:00 PM
Pinser555
Feb 28, 2004 03:55 PM
