Boost and Air/Fuel gauges
#21
RE: Boost and Air/Fuel gauges
you have to floor it and the boost guage will max out somewhere....it might spike then drop down a bit, thats what boost your running. I would make sure you watch it though, if it starts to go higher than around 18 or 19 then get off it and turn the boost down cuz your too high. Also you'll notice that the boost will flucuate with the air temperature, so it may take a couple days to get it right.
#22
ORIGINAL: agallardo
hey guys, finally finished putting both gauges on. Like it a lot. Wish I had the wideband instead, but it wont be long until I order it. Anyway, I have one last final STUPID question.... how can you tell how many pounds of boost you are running?
does your boost gauge read PSI or BAR?
#23
It reads PSI. I did floor it, and it peaks out at 15. That seems way too much. I DONT have a manual boost controller.
The only stuff I have done to it is:
1. Intake with K&N filter
2. Greddy Evo2 catback exhaust
3. Removed BCS restrictor
4. Greddy Type RS BOV
Could this put me at 15 psi?
#24
ORIGINAL: agallardo
#25
yea thats possible with the restrictor removed. I think i was running a steady 12 psi. But dont worry 15psi is good. Its right where you want to be. What does it settle off at like 13
#26
Yeah, I actually went for another run. I floored it again and it would hit 14-15psi for a second or two and then settle around 13, maybe 12. So I guess, I am actually running about 12-13 psi right now?
#29
Hey guys. Sorry to bring this up again. Ever since I plugged up my boost gauge, it seems like i lost some power. I was thinking because I used a t-fitting to connect it to a vaccum line. Could this be why?
antlip
06-11-2007 10:29 PM
importorigins
07-11-2006 02:18 AM
2nd gen spyder 2 gauge pillar pod, autometer lunar boost gauge, and autometer lunar air fuel gauge f
mr casual
07-06-2006 10:59 PM
gsr94trycatchit
12-19-2004 07:27 AM
