Boost controlers?
Old Oct 28, 2005 | 07:31 PM
  #21
Default RE: Boost controlers?
ORIGINAL: Patrick
i think that either im confused, or someone else is...the MBC goes into the vacuum line that assists the waste gate actuator, not the blow off valve.
I think he is a little confued where the MBC goes
Old Oct 28, 2005 | 09:14 PM
  #22
Patrick's Avatar
Administrator
here you go..its crude, i know.
but it will give you an idea of how it works.
[IMG]local://upfiles/3223/4BBDB2DA17AD42D1AD5698D90F613A1D.jpg[/IMG]
Old Oct 29, 2005 | 03:03 AM
  #23
slow420a's Avatar
to get this thing set stright......
http://www.tuneupchile.cl/performanc...controller.jpg
Old Oct 29, 2005 | 12:54 PM
  #24
Patrick's Avatar
Administrator
show off...
what? mine didnt get the point across?
Old Nov 1, 2005 | 03:55 PM
  #25
jerusry's Avatar
i have a slight problem... i am trying to install a mbc on my aftermarket turbo cuz the boost keeps spiking and cutting out... but i dont think the turbo has a vaccum line thing or hle coming from the compressor housing / turbo..... what am i supposed to do? i am freaking out guys!!!!
Old Nov 1, 2005 | 03:57 PM
  #26
jerusry's Avatar
also how do i install an boost guage... it has the vuccum line thing and a set of wires...
Old Nov 3, 2005 | 10:31 AM
  #27
99clipsgst's Avatar
SO from that setup I dont need to run a hose from the bov to the mvc?
Old Nov 3, 2005 | 11:57 AM
  #28
Patrick's Avatar
Administrator
the best place to install a boost gauge fitting is on the intake manifold downstream of the throttle body. on my turbo car, there are a few vacuum lines running to the upper plenum area, and ill tap into that. as for the wires, those are probably for the lights in the gauge.
99clipsgst, youre MBS has absolutely nothing to do with your BOV. the waste gate is what "controls" the boost, not the BOV. the Bov is just there to release the boost pressure when you are decelerating, or shifting, etc. some cars (like mine) dont even come with a BOV, and it allows the pressure to "stack". basically when the throttle body butterfly closes, the pressure backs up all the way down through the turbo housing, which is bad for the turbo unit itself. if you put your MBC in the line between the BOV and vacuum source, you wont have a manual boost controller, youll have a manual blowoff controller, which is just silly, and im not even certain that it woudl work.
anko_kun
Dec 24, 2006 07:48 PM
T76 turbo
Apr 16, 2004 04:53 PM
T76 turbo
Apr 15, 2004 01:02 AM
Pinser555
Mar 5, 2004 10:00 PM
Pinser555
Feb 28, 2004 03:55 PM
