boost controller
Old Jul 31, 2008 | 10:33 AM
needsagst98's Avatar
Default RE: boost controller
hahaha i know. look here. http://www.turboxs.com/uploaded_images/522.pdf i hope im reading that right lol
Old Jul 31, 2008 | 11:25 AM
the turboxs MBC runs totally opposite from every other MBC. So if that is what you have then by all means go by that instructions, but if that isnt what you have then your doing it opposite
Old Jul 31, 2008 | 12:31 PM
iscrewed the screw all the way in and got nothing at all. im getting kind of impatiate with this now. lol. i haved it hooked up correctly from the turbo pressure into mbc and out into the wastegate. not matter what way i turn it it still doesnt go anywhere. i have stock bov. would that have anything to do with it? if so would a 1g bov work?
Old Jul 31, 2008 | 08:34 PM
dsm1990gsx's Avatar
A bov should have nothing to do w/ it.
Old Jul 31, 2008 | 09:23 PM
is the turboxs mbc a ball and srping? is it possible the spring is jammed?. it will not change from 13 psi at all. no matter what
Old Jul 31, 2008 | 10:54 PM
silvercoupe97's Avatar
Your stock BOV leaks at 12psi. That could be why you're only able to get 13psi.
Old Jul 31, 2008 | 10:55 PM
The one thing the BOV has to do with vacuum leaks is the vacuum line connected to it.
Old Aug 1, 2008 | 01:46 AM
ok thanks. how do u install a 1g bov? my buddy gave me one with the stokc metal flange with it? does it bolt up in the same spot?
Old Aug 1, 2008 | 06:46 AM
Yup bolts right up to the same flange.
Old Aug 1, 2008 | 11:46 AM
thanks
Knaackers
Jul 17, 2004 08:55 PM
Knaackers
Knaackers
Jul 13, 2004 04:16 PM
Knaackers
Jun 25, 2004 08:14 PM
Knaackers
Jun 25, 2004 06:01 PM
