boost gauge, firewall
Where should i run the boost gauge hose through the firewall? on a website it says through the throttle cable hole, but thats closed up., should i unbolt the cover to the hole or what hole should i go through
I'd say go through wherever it's going to look good. Whether you have to drill yourself a new hole or go ahead and open hat cover go for a good look and proper installation. Taking th easy way out will only cause you problems later I garauntee it.
i ran my hose through the firewall where the steering column goes through the rubber boot. just tuck it behind the carpet so it doesnt get in the way of anything. it will also come out exactly where you want it to, you're going to want to connect it as close to the intake minifold as you can get.
silvercoupe97
Apr 29, 2007 09:07 PM
snoowboardin58
Jul 9, 2006 02:44 AM
2nd gen spyder 2 gauge pillar pod, autometer lunar boost gauge, and autometer lunar air fuel gauge f
mr casual
Jul 6, 2006 10:59 PM
jimbo_limited
Mar 15, 2006 09:21 PM
