boost gauge, firewall
Old Apr 11, 2005 | 07:08 PM
1998blackgst 240's Avatar
Default boost gauge, firewall
Where should i run the boost gauge hose through the firewall? on a website it says through the throttle cable hole, but thats closed up., should i unbolt the cover to the hole or what hole should i go through
Old Apr 11, 2005 | 10:31 PM
Sanguinius's Avatar
Default RE: boost gauge, firewall
I'd say go through wherever it's going to look good. Whether you have to drill yourself a new hole or go ahead and open hat cover go for a good look and proper installation. Taking th easy way out will only cause you problems later I garauntee it.
Old Apr 12, 2005 | 12:49 PM
DSMTalonAWD51's Avatar
i ran my hose through the firewall where the steering column goes through the rubber boot. just tuck it behind the carpet so it doesnt get in the way of anything. it will also come out exactly where you want it to, you're going to want to connect it as close to the intake minifold as you can get.
Old Apr 12, 2005 | 03:58 PM
mitsunoobie's Avatar
yeah i ran mine through the rubber boot thing in the collum as well and hid it behind the dash all the way to my g pod so i would go through tere
Old Apr 12, 2005 | 05:49 PM
I did it through the steering column boot, thanks alot , looks really good
burnmyeyes
Jan 2, 2008 09:04 PM
silvercoupe97
Apr 29, 2007 09:07 PM
snoowboardin58
Jul 9, 2006 02:44 AM
jimbo_limited
Mar 15, 2006 09:21 PM
