Boost Question
Old Mar 22, 2008 | 04:04 PM
Nabilus13's Avatar
Default Boost Question
What's the stock boost psi of the 2g GST? I checked google, but couldn't find the stock boost pressure (too many modded car sites).
Also, could anyone link me to a pic of a 4g63t with stock vacuum lines? I'm removing a (homemade) manual boost controller in an attempt to fix boost issues.
Thanx
Old Mar 22, 2008 | 06:06 PM
TheAdvocate's Avatar
Default RE: Boost Question
stock boost is suppose to be 12.. But it can range anywhere from 9-12 depending on the car..
Old Mar 22, 2008 | 07:21 PM
sk8dudety's Avatar
it's 12? for whatever reason i thought it was 8...
Old Mar 24, 2008 | 10:15 AM
Im pretty sure your either gonna see around 10-12 psi with the stock BCS. by the way you can use the search feature on this site to find your information. All of this stuff has been discussed before. For a stock setup check out the eclipse FAQ section. There is a diagram in one of the threads
Old Mar 24, 2008 | 11:30 AM
Nabilus13's Avatar
Figured out the problem (99.99% sure). My solenoid valve has NO vacuum lines going to it, so it isn't connected to the wastegate. The prior owner was a F@cking moron.
Old Mar 24, 2008 | 11:51 AM
well they would have been removed if the car ever had a MBC on it
Old Mar 24, 2008 | 04:09 PM
Yep.. Mine is gone completely..
Old Mar 24, 2008 | 04:30 PM
darknigh7th's Avatar
i think i'm just gonna save up and buy an electronic controller, not that it has anything to do with this thread.
anko_kun
Dec 24, 2006 07:48 PM
Mike21
Oct 24, 2005 11:10 AM
GReddyGST
Feb 24, 2005 10:06 PM
antomx
Dec 9, 2004 07:10 AM
RancidSam
Oct 31, 2004 09:00 PM
