bov spooling
Old Dec 18, 2007 | 02:35 PM
atown420's Avatar
Default bov spooling
so with my big 16g my wastegate used to be open all the time. my mechanic changed it to where it only opens when its supposed to. does this change the sound of the spooling. i hear all these dsms reving and you can hear the turbo. on mine i can rev it up and it seems like my doesnt spool like theres. only when im moving can you hear it. i would like to hear the turbo when reving the engine as long as it doesnt cause any performance issues. i tried searching for this and i could only find peeps wanting a loud vented bov. all the pros out there help me im stuck. thanks
Old Dec 18, 2007 | 02:52 PM
Default RE: bov spooling
Your engine has to build boost before you will hear it, and it only builds boost when the engine is under load, IE, moving.
If you rev it up to like 6k you should hear it though.
You dont hear a recirculated BOV anyways. And when you rev it like that you are only building like 6lbs of boost, so its not going to be loud, especially recirculated.
Old Dec 18, 2007 | 02:56 PM
atown420's Avatar
ok well thats what i thought would the wastegate being wide open all the time affect the sound when reving? i just here these turbos spooling at low rpms just when they are reving and not movine. im just envious. so theres really not any way for me to get that even with upgrades? or modification?
Old Dec 18, 2007 | 03:03 PM
Find an example on streetfire.
Old Dec 18, 2007 | 03:07 PM
atown420's Avatar
i dont have sound here at work but when i get home i will post a link up. im just wondering how they do that. ill find a good one and post in about an hour or 2 thanks seb
Old Dec 18, 2007 | 03:13 PM
your wastegate should never be open all the time. Its supposed to only let air when youve boosted and the rest of the air is excess and therefore runs though the wastegate rather than the turbine. alot of these cars that rev it and get all that sound may also have a vented wastegate which alot confuse with spoolup but is actually the wastegate dumping to atmosphere.
Old Dec 18, 2007 | 03:15 PM
atown420's Avatar
the wastegate is that loud? hmm that is probably what im thinking of. how would you get that effect upgrading your wastegate and turbo and ic pipes?
Old Dec 18, 2007 | 03:18 PM
atown420's Avatar
ill get a vid up soon and hopefully thatll help.
Old Dec 18, 2007 | 03:34 PM
are you running an internal or external wastegate. Im gonna assume internal which there are ways to make the wastegate VTA but it would require a new o2 housing like this
http://www.slowboyracing.com/estore/...593&page=1
which routes the wastegate out of the exhaust as opposed to the stock. If its external then it depends on how its routed currently
Old Dec 18, 2007 | 03:37 PM
atown420's Avatar
ya its internal would anything attach to that tube coming off the housing?
