Burning oil bad need help!!!!
Bad headgasket, to make sure, go get a compression tester from a auto perts store. Expect to pay about 30-45 bucks for a good one. Take a drive and let the car reach operating temp, turn off the car and take out all of the spark plugs. Screw the tester into cyl 1 and crank it over 3-8 times, check the gauge repeat for other 3 cyls. The cyls should read between 200 psi and 170 psi. And shouldent vairy more then 25% between cyl's. For example. If you have the numbers for 1-4 as 180,150,150,180, you have a blown headgasket. Normally a blown headgasket takes the psi of other cyls down with it.
If you have the non turbo (420A) Chrysler engine- it is VERY VERY common for the head gasket to leak at the drivers side rear corner of the cylinder head. This major leak finds it way down the back of the block and can drip onto the exhaust system and burn. Theres an updated (MLS) headgasket available from the factory including revised torque specs for the head bolts. It can get bad enough to cause oil burning from number 4cyl. Good Luck!
Joel, CA
Joel, CA
ORIGINAL: Joel_CA
Joel, CA
Joel, CA
Plus he said that he put a pice of card board under the car for the nigh and it was dry the next day.
Joel, CA
the3Gz
Jun 2, 2014 02:06 PM
